1983 Suzuki lt 125 spark, fuel, and air no start!
Old Mar 19, 2023 | 12:31 PM
olive90986's Avatar
Default 1983 Suzuki lt 125 spark, fuel, and air no start!
I got a 1983 Suzuki lt 125 when I bought it the guy got it running when I got it home I couldn’t get it to run, turns over good, has spark, even tried spraying starter fluid right into the cylinder and nothing…..
Old Mar 20, 2023 | 03:27 AM
Check compression, if below about 90psi it will probably be bad to start. If compression is down, check valve clearances. If compression is OK try a new spark plug. Engines with carbs need a bit of throttle before they will start as a rule. They also may, or may not, need choke. Balancing how much of both, to get a start every time, is part of the learning curve. If you get it wrong, you may "wet the plug" and there is then no way it will fire up until it dries out again.
Old Mar 22, 2023 | 09:12 AM
olive90986's Avatar
The compression is around 70 psi so probably won’t start?
Old Mar 23, 2023 | 02:45 AM
Yes, once started it would run, though power would be down. Check those valves and hope it is just lack of clearance causing the compression problem. Otherwise, it is take head and cylinder off, and a check for bore wear, ring wear and bent valves.
cbenson2012
Jun 5, 2022 07:23 PM
Madore33
Aug 17, 2013 10:06 PM
jamiewny
Oct 11, 2011 06:22 AM
izzy3338
Aug 2, 2005 11:55 PM
