front end shakes
Old Nov 11, 1999 | 01:05 PM
shooter's Avatar
I just found this forum and it looks like there is a lot of good info here. I just got a 94 400 4x4 and when I get up to about 30 or 35 the front end starts to shake any Suggestions ?
Old Nov 11, 1999 | 08:32 PM
motorman's Avatar
if you are using flatproof in the front tires that could cause this problem
Old Nov 11, 1999 | 11:16 PM
corncob2's Avatar
Also check to see if you have mud behind wheels or check steering arm or tie rods Cob
Old Nov 12, 1999 | 12:49 AM
A400L's Avatar
Is there a difference when in 4WD? Check the end of the steering stem where the tie-rods connect. Replacing the bushing at the end of the stem with HPD's bronze($30) would'nt hurt either. Also check the "toe" of the tires. OEM specs for my '99 call for them to be slightly out.
Jerry Goodman '99 400L, '98 TBlazer
Old Nov 12, 1999 | 02:22 PM
pflueeb's Avatar
make sure there are no squirrels or chipmunks up in the suspension. They like Polaris too.
No, actually, check your tie rod ends--both inner and outer.
Old Nov 14, 1999 | 11:42 AM
Kagey's Avatar
I can certainly testify to the tire sealer making one shake especially when the tires are cold seems all the sealer goes to the bottom of the tires when you park for a while then it takes a while for it to get spread back around evenly and balance the tires. Thank goodness I got these new mudrunners.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
Old Nov 15, 1999 | 12:27 PM
shooter's Avatar
Thanks for the tips I found out this weekend that it has tire sealer in it and it has been just sitting for about 4 months I pulled the tires off my friends and put them on mine and no more shake I broke the bead on one of the tires and the tire sealer was all clumped up so I thinks this is a good excuse to get new tires.Has anyone used the new ITP Trail wolf tire yet?
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
