How do I remove cam chain DS 650
Old Sep 15, 2023 | 10:35 PM
FarmerRandom's Avatar
Default How do I remove cam chain DS 650
I can’t figure out how to remove the cam chain and cams from my ds 650 (2001) and really need some advice.
Old Oct 9, 2023 | 04:54 AM
brookschofield1's Avatar
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->Here is a way which I usually use. I hope it might work for you too, firstly take out the cam chain adjuster, then you need to lift the cam enough to pull off the bearings, after that you will be able to get the chain off the cam and slide it out.
Old Sep 9, 2025 | 03:09 PM
syahux's Avatar
As far as for The tensioner it is hydraulic, it uses oil pressure to press on the chain. It comes out the back side of the jug. Don’t have to remove anything. Looks like a plug on outside.
snaptube vidmate
baddkarmaracing
Jan 24, 2010 08:02 PM
Rockrimmon
Technical and How-To Articles
Aug 4, 2009 06:41 PM
ERBEDS650
Jul 24, 2007 05:57 PM
ProXPredator
Apr 16, 2003 02:16 PM
