94 Suzuki lt-f 250
Old Feb 1, 2024 | 04:19 PM
shankathome@comcast.net's Avatar
Default 94 Suzuki lt-f 250
Front brakes- won’t bleed I installed a new hand brake master and filled it with fluid but it won’t bleed out ? Please help ?
Old Feb 2, 2024 | 03:12 AM
This is a "frowned on" bit of advice as it is said to damage the pipe, but it works. So, get a vice grip wrench and pinch the flexible pipe a couple of inches from the master cylinder, it only needs enough pinch to stop the lever from working, un-clamp. Open a bleed nipple. press lever fully down, clamp on, let lever off, clamp off again, repeat until fluid starts to flow from bleed nipple.
Old Feb 3, 2024 | 03:27 AM
Re-your private message, what is it doing? Can you not get the lever to lock solid when you have the hose clamped? If so you have not got it clamped properly, or have no fluid in the cylinder. Put clamp on, slacken the Master cylinder banjo bolt a turn and press lever down, some fluid should start to bubble from banjo. Tighten banjo and let lever off, a big gulp of fluid should then disappear from the reservoir and the lever should now refuse to go down when the hose is clamped. Make sure you don't run short of fluid in the reservoir as you bleed.
Old Feb 4, 2024 | 05:48 PM
Default 94 suz quad runner
I’m going to remove front wheel and check if brake wheel cylinder is moving or rusted out ?
Old Feb 5, 2024 | 03:25 AM
As I wrote above what is it doing? Symptoms of a seized slave cyl are totally different to those of air in the system, in fact you get a lever that locks solid but the wheel still turns, or a wheel that is stiff to turn whether the brake is applied or not, if a slave cyl is sticking.
Airman84
Sep 4, 2011 11:26 PM
kookycolo
May 26, 2007 09:22 AM
Lamar
Sep 8, 2003 09:32 PM
scrambled6910
Apr 19, 2003 07:35 PM
