2014 Suzuki King Quad idle problem
Goid day
im fairly new here and am wondering if someone can help me trouble shoot my idle problem with quad.
it's a 2014 Suzuki King quad with power steering.
IfI hold the throttle about 1/16 " it will idle all day. As soon as I let it go it immediately stalls.
Any ideas.
Tha ks for now
Mike
Any ideas.
Tha ks for now
Mike
Check for a fault code, but with that model it is often a blocked injector. As well as the fuel filter in the tank, there is a tiny filter built into the injector, if you remove the injector and blow an airline at the intake, you can usually shift any dirt in there. Other causes can be the tank filter or the fuel pump pressure down, it should be about 50psi, trouble is finding a pressure gauge with the right connections for those fuel lines. 700s had an adjustable throttle position sensor, you set it by using the fault code reader but 450s TPS's were fixed. Not sure about 750s and 500s. I've never got the later workshop manuals as they are so similar in most ways.
