How bad is it?
Old Mar 17, 2024 | 11:48 AM
Woomer Trey's Avatar
Default How bad is it?
This needs replaced correct?
Old Mar 18, 2024 | 03:08 AM
Seems a bit odd it isn't leaking oil through the hole. My guess would be it has dropped a valve which has come back up and knocked a hole in the head but the only way to tell what has happened is to take a look. Heads, pistons and cylinders for those engines are cheap anyway.
Old Mar 18, 2024 | 08:44 PM
okay i plan on taking it off tonight, so I'll check over everything. It was running okay. i noticed there were 2 different tie rods and when i stood up the quad i just so happened to see it.
Old Mar 20, 2024 | 03:23 AM
If it runs OK and doesn't leak oil from the hole it could just be a casting fault which, by pure luck, hasn't opened into anything that matters. "If it ain't broke, don't fix it"
Old Mar 20, 2024 | 03:50 AM
touche', fair enough. tho sometimes when starting it up, you fan feel and hear it make a "clank" like metal banging metal sound. So i was assuming that first reply of your might've hit the nail on the head.
saleh15
Where to Ride
Dec 23, 2008 02:55 PM
