no spark Coleman at 200b
Old Mar 20, 2024 | 05:46 PM
ashton5308's Avatar
Default no spark Coleman at 200b
Need some help with no spark issue. Nephew was riding and ATV just stopped, it hasn't cranked since. I've replaced almost every electrical component. While checking voltage from stator I noticed I get good voltage on the red/black wire when it's unhooked. But when it's plugged back up I get nothing. Checked ground and they check out. I've replaced stator, magneto, ignition relay, cdi. Any ideas?
Old Mar 21, 2024 | 03:24 AM
You can get dud new components and end up adding faults. Someone on here was reporting that new stators for smaller (Honda Cub clone) engines were being sent out with too big a distance between trigger coil and flywheel. However, all you can do is the tests in the help diagnose stator sticky at the top of the engines section of this forum. This should point out which part of the circuit has a fault, which will be either that component or the wire(s) to it.
Old Mar 21, 2024 | 01:33 PM
ashton5308's Avatar
Thanks I'll look that over and see what i come up with!
Old Mar 24, 2024 | 08:37 AM
ashton5308's Avatar
Parts check out. Does showing voltage unhooked and no voltage when hooked prove a wire issue? Ground checks out, maybe a short?
Old Mar 25, 2024 | 02:53 AM
I never check things with them connected to the CDI, except the CDI to coil lead, but as the volts are being used by the CDI I wouldn't think this signifies anything. However if exciter and trigger coils test as good at the CDI plug, and kill wire tests as earthed one way and open circuit the other, it has to be a CDI fault if the CDI isn't sending the high voltage surge to the coil once a rev.
Old Mar 25, 2024 | 05:31 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is CDI dc volts?
Old Mar 25, 2024 | 05:33 PM
ashton5308's Avatar
Thanks! I'll go over cdi again, learning here lol
It's AC
her chee rider
1) Engine problems..
Oct 3, 2021 08:59 PM
nicholasbishop
Sep 6, 2020 09:38 PM
Guillaume732
Aug 22, 2019 04:27 PM
jhorns
May 29, 2018 01:48 AM
rascalefellow
Mar 17, 2008 08:12 PM
