Please help wiring diagram
Old Jul 10, 2024 | 07:00 PM
Tjb5765's Avatar
Default Please help wiring diagram
Please help
Hello I have a 6 pin cdi not sure if it is a bashan or Kudiak or something else I rode it for a few month and randomly caught it self on fire so now I need a wiring harness but can’t figure out why it won’t start it cranks but no fire only if you jump the solenoid is the only way it will crank the electric start won’t work I’ve bought 3 different harnesses and none of them seem to work it’s what I call Frankenstein cause it’s most definitely put together with different atvs judging by the welds on it but I need help with trying to figure out what wires are what and where they go or what Kind of wiring harness I would need to buy any help would be appreciated
Old Jul 11, 2024 | 03:52 AM
First you need to work out what those 6 wires to CDI do. Assuming your bike uses Honda/Chinese standard wiring colours, a black/red from stator to CDI would indicate an AC CDI, but the basic AC CDI only needs 5 wires so one extra wire does something slightly non standard if it is AC. Generic wiring harnesses are mostly for bikes with Honda Cub clone engines, so unlikely to fit your upright engined bike. If you can't find the right harness for it, you will have to make one, or heavily modify a generic one. This diagram shows the basics.
"Safety switch" is a lockout which you can ignore, just connect black to green/yellow, and most bigger bikes have three yellow from stator to regulator rather than a white and a yellow, but otherwise, find out what that extra wire to CDI does, then follow the basic diagram and you should get a starting and running bike. Lights, horn etc, would need wiring to take pos power from that ignition switch black wire.
NiiFoo
Apr 10, 2020 01:11 AM
Lowandroll
Jan 6, 2016 08:28 PM
M38Jeep
Aug 28, 2008 07:29 AM
infinitycyclesupply
Oct 25, 2006 02:25 PM
