Prairie issue
Old Nov 29, 2024 | 07:58 PM
Mac15b's Avatar
Default Prairie issue
Hey guys, new user here and a new Kawasaki rider! I have a 2010 Prairie 360 that I just bought. It can be a pill to start. Starts on choke, but dies without throttle. Previous owner said he always had to mess with the idle screw. It also has the tendency to “surge” as shown in the video with a touch of a “miss”. Any suggestions?!
File Type: mov
Old Nov 30, 2024 | 03:19 AM
Set valve clearances, if they are tight, compression will be low, this makes them bad to start. Fit a new plug. If it still isn't right, check compression, if over 90 psi, assume the problem is carb. Give it a clean, blowing jets and passages out with compressed air. Do not alter or remove jet needles at this stage. Check choke is working properly, and that carb diaphragm is OK. Check the manifold for air leaks.
Racechick73
Club News and Events
Oct 2, 2004 11:20 AM
trailride
Oct 28, 2003 10:49 PM
prairievenom
Feb 23, 2003 09:20 PM
