2007 Honda TRX 250 wont start
Old Jan 8, 2025 | 05:58 PM
eddiecan2's Avatar
Default 2007 Honda TRX 250 wont start
Hi Y'all. I'm new here. I have spent the last 3 evenings trying to get this thing running again. My ATV just stopped starting up seemingly randomly. When I hit the electric start it turns over and just tries and tries but never starts.
I have:
Installed a new carborator.
Checked to see that fuel is running down the fuel line when I remove it from the carb.
I am using the electric start function.
It runs and fires if I spray some carb cleaner into the front of the carb.
So I'm pretty sure it has spark because it fires up with the carb cleaner. I know its not the carb because I just replaced it. Fuel just runs and runs out of the fuel line if I remove it from the carb and turn open the petcock.
Could it be bad fuel or something I'm not even thinking of?
Old Jan 9, 2025 | 03:42 AM
Check properly for a spark, change plug and do a compression test. Check for water in the float bowl. 250s have a known fault, in that the cam chain tensioner breaks and lets the chain jump a few teeth, putting them out of time. However, if compression is down (below 90psi) it could just be faulty valve clearances, wear in bore or rings, or a light seizure.
Hunter44
Oct 5, 2019 08:09 AM
Wargle
Mar 10, 2010 10:47 AM
LtJake
Sep 24, 2008 12:13 AM
OneFastChevelle
Jun 24, 2007 03:58 AM
AndysLakota
Jul 5, 2001 09:43 AM
