flooding polarise
Old Jul 5, 2001 | 12:43 AM
AndysLakota's Avatar
i have a 95 polarise that keep flooding out if you go to start it you half to put gas in the carb to get it to start. just a little gas in the carb then it runs and then quits what could i do for it
Text
Old Jul 5, 2001 | 02:15 AM
articcatsux's Avatar
well this is a POLARIS fourm so i dont know any thing bout a polarise just jokin with you man
Old Jul 5, 2001 | 09:17 AM
Duner's Avatar
Sounds like a carb problem or plugged fuel line. Replace the fuel line first because it is cheaper and easier. The next step would be to remove the carb and inspect it. I had the same trouble with my dune buggy. The problem ended up being sand that got into the carb and clogged up the lines. Good luck.
Old Jul 5, 2001 | 09:43 AM
Farmr123's Avatar
Don't forget to check the fuel filter.
Customer Service #1
May 15, 2020 08:46 AM
Jason Poulin
Sep 20, 2015 02:49 AM
Jaymc
Sep 11, 2015 07:45 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
1000gade
Jul 16, 2015 10:48 AM
