View Poll Results: Why would coil stop firing when you plug ground wire up?
Firing issue
100.00%
Coil problem?
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Firing issues with a 03 250 recon
Old Feb 22, 2025 | 12:52 PM
Rustybent's Avatar
Default Firing issues with a 03 250 recon
Why would coil stop firing when you plug ground wire to it
Old Feb 24, 2025 | 12:12 AM
https://atvconnection.com/articles/a...when-grounded/
Old Apr 7, 2025 | 05:14 AM
Rustybent's Avatar
Replaced coil ,wiring harness, cdi and rectifier, same issue, checked every ground on it, and now the netural light will not come on unless you ground the netural saftey switch to the battery, I have been working on atv's for years and have never seen such a problem, if you could figure out anything else would be great , but I'm running out of options here I have replaced everything on the bike but the netural safty switch, but it's sending power threw it with it disconnected from the switch itself were it goes into the engine, this is really annoying, I don't know we're else to turn
Old Apr 21, 2025 | 03:40 AM
Neutral wire will show pos, as pos flows through bulb and is earthed by the switch when in neutral, to make the bulb light. So you have a faulty neutral switch. Just a possibility but is the engine earthed properly? I guess both your problems could be caused by that.
Rustybent
Feb 22, 2025 12:36 PM
recon rider 10
Dec 27, 2021 04:58 PM
bbobcean
Jul 26, 2007 10:13 AM
SpeedySB
Jan 14, 2006 04:28 PM
rambo700
Jul 22, 2005 12:26 AM
