Coolster 110 electrical issue
Old Apr 6, 2025 | 06:30 PM
lph008's Avatar
Default Coolster 110 electrical issue
Have a coolster 110 and it wont crank. Replaced battery, harness, coil, cdi, ignition, kill/starter switch, stator and harness. It wont even try to crank. Previous owner lost key and when I tried to replace the key ignition, it melted the ignition wires.
So I replaced everything but I can't get it to crank
Old Apr 6, 2025 | 07:00 PM
djshad1469's Avatar
You need to hold or press the brake unless you bypass it.
Old Apr 6, 2025 | 07:11 PM
lph008's Avatar
Yes i tried both brakes, also bypassed brake switch and nothing.
Old Apr 7, 2025 | 11:43 AM
lph008's Avatar
Little update. I missed the ground that bolts to the stator cover, but now when I hook battery up it cranks and it's cranking with the key off and kill switch...?? As soon as I connect the negative to battery it cranks on its own.
I'd rather have to pull the motor apart than diagnose electrical lol
Ianh7784
1) Engine problems..
Apr 16, 2023 02:05 AM
palomba16
Apr 9, 2016 02:02 PM
monty92781
Feb 23, 2014 09:44 AM
kanatuna97
Technical and How-To Articles
Apr 24, 2008 01:30 AM
