magunum 325 4x4 shakes
Old Nov 14, 1999 | 01:03 PM
bowtiepu's Avatar
do all the magnum 325`s shake at an idle in neutral? engine shakes and the handlebars and rear fenders jump around..is this normal?
Old Nov 14, 1999 | 01:57 PM
mudmachine's Avatar
yeah, the 325 4-stroke has a vibration at idle.. My buddy has one (2x4) and it started making his hads numb after riding for awhile. We installed the foam cushion grips and that helped a little. So, we took the grips off, and got a tube of the flowable bathtub silicone (ya know the stuff you use in a cauking gun) and filled his handlebars full of it. Then we re-installed the cushion grips... THAT HELPED ALOT!!... The silicone REALLY quells the vibrations and what it doesn't catch, the foam grips do...
Good Luck!!!!
Old Nov 14, 1999 | 07:18 PM
dand11's Avatar
Check your motor and see if it has three or four motor mounts. Polaris sent a bulliten to the dealers with instructions on how to remove an extra motor mount to reduce the vibration. Mine came from the factory with the extra mount removed so I guess it was only the very early 2000s had the extra mount. This is not a recall item you must ask about it. If they play stupid I have a copy of the instructions I can send to you. But the vibration reduces a lot once you get around 40 hours on the machine. This is the first ATV I have ever owned and I don't think it vibrates too much as compaired to new.
Happy Trails
Dan Daugherty
toonces
Sep 5, 2015 01:14 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
austinwhitton
Aug 11, 2015 06:21 PM
Phildogg
Dec 4, 2000 08:52 PM
