Polaris 330 Clutch Weights Tuning
Old Aug 26, 2025 | 05:27 PM
TrailBlazerRider08's Avatar
Default Polaris 330 Clutch Weights Tuning
Thinking about doing some clutch tuning to my Polaris TrailBlazer 330. What weights should I go with for the best acceleration? Not sure what stock is, but I think it might be 46 grams. I can provide more info about my quad if necessary. Thanks!
Old Aug 27, 2025 | 08:04 AM
Red64's Avatar
Default Weights.
The weights and spring change only affects the engagement rpm of the clutch.
Old Aug 27, 2025 | 03:47 PM
From everything I have been told in the past, the lighter the weights, the faster it would be off the line. Maybe I'm wrong.
Old Aug 27, 2025 | 03:48 PM
Old Sep 1, 2025 | 02:29 AM
There has been a discussion on this in another thread recently. My two pennywoth, lighter weights make the variator change up at higher revs, rather like staying in second gear to higher revs with a manual gearbox. So, in theory better acceleration. If it has a variator which uses the belt as a clutch, lighter weights would also mean higher revs before the clutch bites, as noted above. However, I find low geared variators don't feel to be giving better acceleration, as "staying in second" means you are revving the nuts off it while not going particularly fast.
buck1992
Jul 30, 2008 12:51 AM
SHOTGUN
Apr 2, 2004 01:59 PM
sliderm
Feb 5, 2003 01:51 PM
