Polaris 500 6x6 2006 does not operate normally
Old Aug 31, 2025 | 07:21 AM
soniz's Avatar
Default Polaris 500 6x6 2006 does not operate normally
Hi, I have an atv according to the title, which is a bit strange. When you drive straight ahead, it sometimes pulls to the right and sometimes to the left, so you have to steer against quite a lot. And now I notice that when you reverse, the front wheels seem to spin more slowly than the rear because they seem to be dragged a bit. I think they seem very strange, so I'm wondering if anyone has experienced something similar and can offer some advice on what is wrong. All tips are appreciated!
Old Sep 1, 2025 | 02:10 AM
I don't know the model at all, but if the wheels "seem to be dragged a bit" I would suspect the brakes. Wandering steering can be tracking wrong, or worn steering and/or suspension joints, but I guess if one side brakes stuck it would pull one way, then if the other side stuck it would pull the other way. If it has 6 wheel drive, front CV joints or diff problems can make steering odd, but usually pulls to centre, or heavy steering.
Old Sep 1, 2025 | 03:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
It almost sounds like one side or the other of the awd is activated when the other is not. I can't remember if that model had the magnets in the hubs or not. when is the last time the front end was serviced? If it is the hub style w/ the magnets(it's how the awd is activated) then it might need a oil change using the correct fluid.
tompeter
Mar 21, 2021 02:21 AM
coacho
Jun 27, 2008 10:15 AM
brpbear
Sep 11, 2006 08:30 PM
