Lost why it won’t startz
Old Nov 14, 2025 | 09:07 PM
Brandi1's Avatar
Default Lost why it won’t startz
Hello I had my atv being stored at a friends house . He do a tune up and checked everything out . Well now I need it to get ready for winter plow and it won’t start . This is what he told me. there is an EFl code that says the crank position sensor is not reading , I ohm metered the sensor and it is within spec, the fuel pump also does not turn on but if direct power is put to it it pumps so I'm at a loss I tripled checked all the fuses, I replaced relays I checked the power wire going to the crank sensor it was only reading like 3 volts not sure if it's the computer that's bad, the wiring harness itself or what I'm at a complete loss if you know somebody else that knows more I can haul it to them.
Old Dec 15, 2025 | 12:37 AM
We have the information you seek on the ATV Connection homepage here:
https://atvconnection.com/forums/arc...it-startz.html
Old Jan 4, 2026 | 02:24 PM
seriong_hoo's Avatar
The symptoms primarily indicate a power or grounding issue with the engine control unit (ECU) rather than a faulty crankshaft sensor. The EFL code appears because the ECU is not receiving the signal correctly, which also explains why the fuel pump is not priming, even when operating with a direct power supply.
Albert6
Jan 17, 2016 09:14 AM
katt68
Jan 13, 2012 03:18 PM
Dylan Robinson
16
Sep 20, 2011 11:38 PM
red_baron
Apr 26, 2010 11:05 PM
