Anyone Had Problems Starting Your Cannon?
Old May 6, 2001 | 02:27 PM
Blodg500RX's Avatar
I read in a mag. that the bike had trouble starting for no reason some times. And I have read that a guy couldn't start his quad after washing it and another had the wrong clip or something in the starter.
Just wondering how common these problems are. I read on the Cannondale website a procedure for starting. It said hold throttle open 1mm and crank for no more than 2-3 seconds at a time. I wonder if the people having trouble starting were not following the proper procedure. With my quad there is definately a drill that MUST be followed when starting it or it will not fire.
Any input would be appreciated. It would have to be extremely frustrating having a brand new quad that would not start. Thanks.
B-T-W, where did the post on the new pipe dyno results go?
Old May 6, 2001 | 05:11 PM
minehunter's Avatar
I think the moderator deleted it because it had a name and phone number in it. He probably considered it advertising.
Old May 6, 2001 | 10:42 PM
cddcpa's Avatar
I have reposted my dyno info. Why would anybody call it advertising? My name and number to talk to any FX owners who care to call? I didn't even tell anybody to call the manufacturer, just me. If somebody calls I was going to tell them all about what I have done. There is only about 200 FX owners and only two of us are posting info on this site, I put my email, name and phone number just so I counld talk to any other owner who wants some info. I'm trying to get info to owners that haven't got any at all. Sorry for the rant!
Old May 7, 2001 | 02:37 AM
86atc250r's Avatar
I know a guy that has one... He said no troubles so far. He also advised me to not touch the gas when starting it. I didn't, it fired right off. Just like a fuel injected car or truck...
cddcpa - if you hadn't noticed before, the moderator(s) here are a bit **** & like to delete valid info if they even "think" that it might in some way be considered "advertising", but will allow all the flaming, trolling, & just plain ignorant posts to continue as usual.
Heck, I'll probably get banned again for speaking up...
Old May 7, 2001 | 07:36 PM
cddcpa's Avatar
I'll try to tiptoe around, good grief!
Old May 8, 2001 | 12:50 AM
Canman's Avatar
i had the problem with it not starting after i washed it the first time but it was not because of the water. What happend was one of the wires for the fuel pump came loose. Nothing a little lock tight could not fix. But shure did give me a scare.
Old May 8, 2001 | 12:55 AM
86atc250r's Avatar
That sort of problem is not isolated to Cannondale though.... My battery connections (both positive & negative) have come loose on my 400EX causing it not to start. After I loctite'd them, I had a wire get pinched that energizes the solenoid (too much jumping), it wouldn't start (till I figured it out), and last but not least, I broke a negative battery cable at the terminal on the frame (too much jumping). Replaced with high quality 4 awg cable and gold plated terminal, no more problems....
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
minehunter
Jan 11, 2001 08:53 AM
