Dissapointing power results
Old May 10, 2001 | 08:59 PM
wheeliedude's Avatar
I recently bought a 150, and 155 main jets along with 6 filtered uni vents for the airbox. I tried a bunch uf setups and found no more power. I thought that a 155 main with no airbox lid would give me more power. it didn't. I have a bike speedo(sure it isn't completly accurate) to test and seat of the pants. I could wheelie easier in 4th and 5th stock. also stock, I went up a long up hill run and got 94km(59mph) with 155mj and no airbox lid I got 92km(57.5mph) I repated the procedure 3 times each way and got the same results. the 150mj and 6 pluged vents feels like stock and I got 94km on the same hill(same speed as stock) the plug reads a light brown color stock and with the 155 and no lid. and yes I checked it at full throttle.(burnt my hand the first time checking the plug) I thought that this was a good way to get more power, but I saw none. all is stock except 3 holes in the end of my stock pipe(behind the spark arrestor) I also wonder if the 155 was getting too much air with no lid. also the filtered vents seem restrictive.(hard to blow through) any suggestions to get more power?
Also, will a 40 or 42 pilot help my bottom end?
maybe I should go with a uni filter, maybe a jet kit? Pipes seem to expensive. thanks.
Old May 11, 2001 | 11:13 AM
xtreme165's Avatar
Dont expect to get any noticable real power gains from just airbox mods expecially with the stock pipe. Dont believe all the advertisement and hype, although with a aftermarket exhaust you will notice a little gain. Air box mods will give you better throttle response but nothing real noticable, get a exhaust and you'll notice some gains with the added air flow!
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
