anyone have the edelbrock carb for 400ex???
if u have the edelbrock carb i have a couple of questions for ya?
u got any pics of it?
is it worth the expensive price tag?
does it mount perpendicular with the manifolds or do u have to mount it sideways like the lectron?
can all the adjusting be done with the carb attached to the manifolds?
what can i shave the throttle housing with?
ill prolly think of some other questions later.... thanx in advanced for your reply
peace
bc
peace
bc
Hey BC- I have an Edelbrock on my ex and am totally satisfied with it. It mounts in the stock manifold just like the stock carb did. You can change low-mid rpm jetting with the carb on the bike using the mixture tool that came with the kit. It looks like it would be easier to remove the tank to make the high rpm adjustment (changing a needle). Mine still has the factory needle in it, I had to lean the low end mixture a couple of clicks. Hope this helps you.
