18x9.5x8 or 18x11x8 Turf Tamers?
Old May 13, 2001 | 06:27 PM
wcy2k400ex's Avatar
What is the difference between these two tires, besides the obvious? Is one better than the other on a 400EX? Thanks.
Old May 13, 2001 | 06:43 PM
zeebo's Avatar
I would say the 18x11x8 would be beter because 18inch tires are easy to spin from the start so i would go with the wider ones so your not just sitting there spinning .
Old May 13, 2001 | 10:40 PM
DIEhardRlDER's Avatar
to turf tamers last along time? i ride mostly on hard pack and sometimes the road when i have to.
Old May 14, 2001 | 12:44 AM
hakmazter's Avatar
I run the 11s and never tried the 9.5s, but i think they would be worse for traction. I have virtually no treadwear after about 50 hours of hard use. They are definitely better than the stockers for wear.
Old May 14, 2001 | 12:59 AM
RAZOR13's Avatar
the 11's are the ones to go with you can use a gruver to make a coustom tread desing if you want they are light and stick whitch = HP's and cheep
Old May 14, 2001 | 07:24 AM
chriscoll1's Avatar
9.5's give more traction on a looser track.The narrower tire digs down to the hard ground faster.
Old May 16, 2001 | 02:09 AM
wcy2k400ex's Avatar
Well, my a friend and I have always heard 11's or 4-strokes, and 9.5's for 2-strokes. I want Turf Tamers that will slide around corners pretty easily, hook up really well, and wear at a decent rate. What do you say I should put on my 400EX? Thanks.
wcy2k400ex
Jan 31, 2001 08:56 PM
grip75
Oct 6, 2000 09:27 PM
luv2ride
Sep 5, 2000 01:56 AM
shollz
Jul 11, 2000 12:18 AM
RidE
Sep 27, 1999 01:05 AM
