broken rubi
Old May 13, 2001 | 10:57 PM
ARMudder's Avatar
Help
I was riding w/ my freind who has a rubicon it wants to cut out in high and reverse like it was out of gas but it doesnt do it in low also it esp d2 d1 it does it and in esp it wont shift up or down and where it reads d1, d2, esp it blinks please Help
any help is appreciated
Old May 14, 2001 | 12:38 AM
N2Mountains's Avatar
Does it blink with 2 dashes? "--" ???? If so the service manual says it is part of the self diagnostic part of computer. It stores a code in memory to tell the tech what to check.
Here's the procedure for getting the code....
put gearshift in "Neutral"& turn vehicle off.
Turn ignition switch on while pushing "up" & "down" shift switches simultaneously.
Release up/down switches immediately, & then push up/ down switches again simultaneously for 2 seconds or more.
the code is displayed on the display by the number of times the dashes blink. The way I read this the last time you push up/down switches in you have to hold them till code is displayed & then release the switches.
It will blink the # of times for the code followed by a 2 second pause then blink again for the 1st previous problem.
Let me know what the code is & I'll look it up & give you some areas to check.
Good luck
It also says turning off & on will reset the shift function & will again disable the shift function if problem occurs again. But I'm assuming you've allready tried this.
Old May 14, 2001 | 05:54 PM
ARMudder's Avatar
ok
i think i get it should be able to tell you the ccode by wed.
Thanks alot also, will that maybe cure the spiting and in hugh the rverse light comes on
thanks again
ARMudder's Avatar
ok
thanks again
Old May 14, 2001 | 06:10 PM
TEXMud's Avatar
ARMudder, the Rubicon has gone into default mode. It does this to prevent any damage. Get that code so that we can help tell you what is wrong with it.
Old May 19, 2001 | 02:09 PM
ARMudder's Avatar
i got it it blinked 5 times
sorry for the wait i could to do ealerier this week
Old May 21, 2001 | 06:08 PM
4x4king's Avatar
Heck with the electrical crap.. I am staying manual. My uncle's Rubi doesn't know what "gear" it is in half the time, either.
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
awer1968
Sep 8, 2015 11:02 AM
