sprocket question
Old May 15, 2001 | 04:27 PM
xploridaho's Avatar
I replaced my rear sprockets and chain. My front sprocket on the rear drive isnt tight against the snap ring, it has some play in it. Not much, maybe 1/8 inch or so. Is this normal?
Old May 15, 2001 | 04:41 PM
honda205X's Avatar
play on the front sproket for the rear chain is perfectly normal..that is like you said 1/8th of an inch, parallel to the shaft. my does that on my dad's x-plorer 300 4x4. the stock one did, and the new stock replacement does it too.
Old May 15, 2001 | 04:53 PM
xploridaho's Avatar
Thanks for the info, now I just need to figure out why the front tires are wearing on the inside.
Old May 15, 2001 | 05:29 PM
ScrambledKiwi's Avatar
Adjust the toein/out using the tierods to stop uneven tire wear.
You should have a slight toe out for best performance.
Old May 15, 2001 | 06:49 PM
xploridaho's Avatar
Been there done that. Still tires wearing on the inside. Maybe its just because they are not real good tires. They are the titan 489s.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
wendal
Sep 15, 2015 01:50 PM
