Compression Test
Old May 18, 2001 | 05:51 PM
ScoobyDFW's Avatar
Is 130 psi bad for a compression check on the DS650 w/o disabling the decompressor?
Old May 19, 2001 | 12:21 AM
burbanator's Avatar
Hey scooby not sure on the compression issue ill run a test on mine tomorrow and get back to you on the results. Was wondering if you know the autometer tach part # so i could see if i could get it cheaper through someone else.
THANKS.
Old May 20, 2001 | 12:25 AM
ScoobyDFW's Avatar
I bought the tach over a year ago from woods, so he could be using something differnt now. My tach is labeled 19205-0802. It is an autometer Pro-Cycle 3 3/4" 10,000 RPM backlit tach. black background and face, white rpm numbers, yellow tic marks, orange needle.
What was your compression reading?
Old May 20, 2001 | 08:04 PM
ScoobyDFW's Avatar
The motor measured 215psi with the auto decompression temporarily disabled. According to the formula:
compression = 14.7*(CR)^(1.1 to 1.2)
we should be somewhere in the range 180 to 225, so my motor is fine.
The valves may be a little too tight though.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
