Trail Blazer Problems
Old May 20, 2001 | 01:04 PM
Honda250exKid's Avatar
My friend has a 98 TB and something is grinding in the back of his quad. It sounds like it has mud and grit in there but it is dry out. His chain is really loose too. Could that be causeing it and is the chain self tighting like all the new Polarises?
01 Honda 250ex
00 Yamaha Grizzily
Old May 20, 2001 | 01:31 PM
Lurch77's Avatar
If the chain is really loose, that would be the first thing to do. Tighten it up to see if the noise goes away.
The chains on Polaris quads are not self tightening. You must do it. Tighten the chain so that there is about 1 inch or so of deflection. The manual says to leave it at 1/8 deflection, but many people have been have serious problems when they tighten it that tight.
Old May 20, 2001 | 01:32 PM
xepathfinder's Avatar
New Polaris atv's with chains are not self tightening. but he really should keep it tightened properyl, most problems with chain drive machines come from not properly taking care of the chain.
Old May 20, 2001 | 02:09 PM
talonhawk's Avatar
The chain may also need to be cleaned and lubricated if its and old chain!!!!!!!!!!!
Old Aug 14, 2001 | 02:08 AM
B350T's Avatar
I know this is an old topic but I might as well give my $.02
The noise is the plastic chain guard, I garuntee it, I have had the same problem, as others have said, just tighten up the chain.
Old Aug 14, 2001 | 01:45 PM
TrailblazerKid250's Avatar
Honda250exkid is talking about me. I always took care of the chain and lubricated it. The only reason i didn't reply to this sooner is because i had it taken care of. I got a new front sproket and chain and i no longer have this problem.
Old Aug 14, 2001 | 02:10 PM
yel400exman's Avatar
omg are you stupid its THE CHAIN GUARD DUHHHHHHHHHH!!!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 14, 2001 | 02:39 PM
yamahagye's Avatar
OH look, it is yel400exman with another one of his comments. last one i heard was how polaris could never build a good quad based on what the have built in the past. has it ever dawned on you that companys can change and make something new and improved. so you have ridden the new polaris quad and know for a fact that it sucks? then you go around telling someone how stupid they are. you need to cool it. stop posting unless you can do it without insulting someone or someones quad.
Old Aug 14, 2001 | 02:40 PM
I didn't do the maintenance on it. I never said i did. The shop did it. And your wrong there bub it's not the chain guard because it's still on there, and i don't here any noise. DUUUUHHHHHHHHHHH[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 14, 2001 | 02:43 PM
Yes yamahagye i agree with you it's always something about Polaris and it's a wise crack every time.
