300ex Motocross setup
Old May 25, 2001 | 05:09 PM
REDTEAM's Avatar
I am planning on racing Holeshots on my stock 300ex rims (will this be good or should I go with a smaller rim) also what size tire should I go with, and then the tire and wheel will change the gearing so What should I go with on the gearing, should I change the countersprocket or the back on or both, let me know
THANKS
Old May 26, 2001 | 07:04 AM
skull's Avatar
I would go with a 20" tire on the stock rims. the stock rims are very strong, being that they have the rolled edge. a lot of people use 18" for motocross though. whatever you think works best for you.
seeing as you have a 14 tooth sprocket already, some 20" tires would bring you close to stock gearing. if you go with an 18" tire you may want to drop a few teeth on the rear sprocket, maybe try a 35 or 36 tooth.
Old May 26, 2001 | 11:57 AM
REDTEAM's Avatar
Thanks, anymore suggestions?
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
jbrewster94
Sep 23, 2015 04:16 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
