400EX Carb on 300EX
Old May 26, 2001 | 03:52 AM
NVR2L8's Avatar
I have a stock carb left over after installing a 39mm FCR carb on my 400EX, and was wondering if anyone here has installed a stock 400EX carb on a 300EX? If so, does it just bolt on or does it require modification? Can you use the stock throttle cable? What jetting changes were necessary?
Old May 27, 2001 | 08:41 PM
bermbanger's Avatar
I saw a webpage that had this, but I can't remember which one it was. Might have been exriders.com I dunno
Old May 28, 2001 | 08:13 AM
quad041's Avatar
it can be done, my freind has a 390 kit on his 300ex but the gas tank needs to be raise for clearence so does the front plastic
http://y42.photos.yahoo.com/bc/quad0...src=ph&.view=t
quad041
Old May 29, 2001 | 07:32 AM
XC426's Avatar
The 400EX carb goes on without any alterations. The stock 300EX throttle & throttle cable works great with this setup also. My 300EX's have a Honda 350X three wheeler airboot on them, which is a direct replacement of the 300EX airboot. A 350X airboot (the boot between the carb and airbox) is slightly larger than the stock 300EX boot. As for altering the tank and front plastic for it to fit, I have had no problems.
Rick
Old May 29, 2001 | 08:50 AM
AL300EX's Avatar
I have a 400ex carb and a 350x airboot on my 300 also, it bolted right up with no problems. There is no need for altering gas tank or plastic.
Old May 29, 2001 | 09:25 AM
cstark's Avatar
Same here, 400EX carb and 350X airboot on a 330EX without any modifications. (thanks XC426 )
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
