Alright Ive got a problem.....
Old May 26, 2001 | 03:03 PM
Daredevil1's Avatar
I got a problem. I was lubing my chain today after washing it and i wiped my chain and the sprocket moved(rear). I mean it moved without moving the axle. It can rotate about a 1/4 inch around the axle forward and backward without the axle moving. I know this probably sounds pretty repetitive. Do you think my axle splines are shot, or those bolts next to the housing are too loose? They dont look loose, but I have nothing big enough to tighten them with. If this is an axle problem, like the splines are shot, does the RPM Dominator 2+2 axle sound good? Also will my quad handle funny if i get the axle, and not the a-arms extended right away? Thanks for any help.
Old May 26, 2001 | 05:58 PM
derekhonda's Avatar
dont know how to help you out with the technical stuff, but i had my back end alot wider than the front (trust me it was about 10-12 inches wider than stock) and it didnt handle too funny. Sometimes though, it acted like a three wheeler on turns. But that was like 12 inches, not 4, you should be alright.
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
