Case porting a Banshee, how and is there much improvement???
Old May 29, 2001 | 04:31 PM
RoostKing's Avatar
The subject says it all. Any ideas???
RoostKing...
Old May 30, 2001 | 09:59 AM
409LongRod's Avatar
It is worth a couple of hp... it also depends on how much your cylinders are ported and how much they are flowing. Cut a set of base gaskets to match your cylinders, and the use them as a template to scribe lines on your case. I ususally use a little bit of yamabond on the gaskets when i put it back together since the gaskets are usually cut pretty thin...
Old May 30, 2001 | 11:03 AM
RoostKing's Avatar
Thanks for the info. One more question. Should the cylinder be ported before you do the case porting? Again, Thanks...
RoostKing...
Old May 30, 2001 | 05:34 PM
H300F's Avatar
so this should not be done on stock ported cylinders?[img]i/expressions/face-icon-small-frown.gif[/img]
Old May 31, 2001 | 09:55 AM
Backcountry's Avatar
Seems my original post has disapeared, it's a ATVConnection conspiracy theory that I have.. [img]i/expressions/face-icon-small-wink.gif[/img]
You can match the cylinders on anything, ported mild, ported wild, bone stock...You're going to see the most gain on a set of ported cylinders, but if you're feeling spunky and don't mind spending some time doing it, then it can be done to an otherwise bone stock engine. I wouldn't go out and pay money to have it done to a set of stock cylinders, but if you've got your cases apart for some reason then you can match things up yourself with a die grinder or dremel.
Old May 31, 2001 | 12:37 PM
H300F's Avatar
yeah i guese i will try it out because i will have the cases apart, i need to replace a crank seal.
i really dont understand what has to be done though.
Old May 31, 2001 | 02:14 PM
Use the base gasket as a template. Compare the base gasket to the cylinder, then to the top case. If there is cylinder block material exposed past the edge of the base gasket, remove that material. If there is gasket mating surface exposed past the edge of the base gasket on the top case, remove that material. If the base gasket protrudes past the edge of the case or cylinder, trim the base gasket...
Old May 31, 2001 | 04:55 PM
H300F's Avatar
ok got it, thanks.
can i destory the cylinders and case? i mean i can understand going too far will definately destroy it, but is there anything else that can defeat the whole pupose of porting the cases?
i am pretty much sure i am going to try this out, i would like to get as much out of the motor as i can, without spended hundreds of dollars (which i dont have, im 17) to get it up there in horsepower/torque.
by the way, will i "feel" any difference when i put it all back together and get out of the trails? how much does this add to stock ported cylinders? (i have T5s, 20over weisco's, no lid, jetted, and i am going to add a veto timing advance, and maybe lighten the flywheel)
Old May 31, 2001 | 05:35 PM
Go slow, take you time, you can always cut it twice. The proper tool and technique goes a LONG ways...Don't half *** a $1500 engine...
Use the gasket as a template...
The gains are going to be small, maybe not even discernable, but it's not going to hurt if done properly either...
EIF
Apr 20, 2017 07:15 PM
franklyme
Oct 21, 2016 07:18 PM
WilliamBos
Sep 22, 2015 04:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
antiguogrumete
Sep 5, 2015 03:41 AM
