stiffer suspension?????
Old May 31, 2001 | 11:40 PM
articcatsux's Avatar
i have a scrambler 500 4x4 i love it but when i jump some time it botoms out i have seen these rubber pieces that go in the front suspension if u are pushing snow will they work in my scram and stiffin up the suspension??????
thanks polaris rules
Old Jun 1, 2001 | 12:02 AM
bermbanger's Avatar
I've never saw any before (except on nascar) but you could make some and it might help. Either that or have them revalved stiffer. I would have them revalved if its possible on struts.
Old Jun 1, 2001 | 12:14 AM
mtpockets's Avatar
articatsuk,
i don't own a scrambler but i can tell you that i jump my sportsman and it's a little improvement vs not using them. not a big difference. i guess to do it the right way, progressives would be the way to go.
Note: i bought mine mainly for plowing snow to keep that front end up. and for plowing, it does a great job!
Old Jun 1, 2001 | 10:26 AM
bubba1005's Avatar
It's hard to believe your suspension is too soft on the scrambler. However you can buy the fox struts which are rebuildable, and add the progressive springs and adjusters this will make your front suspension very adjustible. The stock struts do not last very long. I killed mine in about a month.
Old Jun 1, 2001 | 10:48 AM
4wheelitis's Avatar
I have a 2000 500 sportsman, If I ride the whoops hard I rub the fronts. I put the spring rubbers in for plowing last winter, that helped the sag from the weight of the plow, I left these rubbers in this spring. I still rub on big whoop sections. I am going with the adjustable spring kit from progressive to stiffen it some, I need it for my size to stiffen it even more. I have the backs as stiff as they go, works perfect for me, when I get the fronts dialed in should be perfect.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Mssarabug
Aug 10, 2015 12:56 PM
Wnthunting
Jul 9, 2015 03:02 PM
