Rancher.Front wheel bearings
Old Jun 2, 2001 | 11:50 AM
rancher2000's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]How's the front wheel bearings doing on your Ranchers?
I have 900 miles on mine.I can feel slight movement when i grab the top and bottom of the tire and wiggle it.Do you think i should be concerned or is there a lot of life left in the bearings?
Old Jun 2, 2001 | 03:00 PM
springdrl's Avatar
It doesn't take long to find out if there is real problem. Remove the wheel and check to see if the screw is loose on the spindle. If not, the problem is probably with the bearings. It's a good idea to clean and grease the front hubs at least once a year anyway.
Old Jun 2, 2001 | 03:44 PM
bermbanger's Avatar
I would clean them out and replace them, then pack the bearing with some water proof anti seize grease and you shouldn't have to touch it for a few more years if you clean them every once in a while.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Cantbuytime
Aug 16, 2015 09:13 PM
toonces
Aug 5, 2015 05:55 PM
