Anyone mount winch on your 650?
Old Jun 3, 2001 | 10:09 PM
92LT's Avatar
I was just curious if anyone has mounted a winch using the stock mount on the 650. I want to get a Warn 2500, but I'm not sure it will fit because the mount is for a Warn 2000.
Old Jun 3, 2001 | 11:54 PM
Mudrunner12646's Avatar
Kawasaki Has a bracket for the mounting of a 2500 winch optional pieceI was told it was part# KVF650-050
Old Jun 4, 2001 | 08:37 AM
prairie633's Avatar
I think the Warn 2000 and 2500 use the same mounting footprint, maybe the same winch. I believe the difference is that the 2000 uses a manual switch contactor and the 2500 uses the remote mounted contactor, which is just a high amperage relay allowing more current flow probably. The mounting plate is Kawasaki number KVF650-050 and is under $30. Mine arrived and didn't fit. I called Warn engineering and they pulled the CAD drawing. The mounting plates made on 5-12-01 had the bottom bend reversed 180 degrees. I don't know if all of them are wrong. I am waiting for Kawasaki to go through their inventory in Atlanta and pick out a good one. It looks like it will work, but the design puts more stress on the original Prairie bracket because the winch has to mount feet-first and with the cable spooling from the top. This levers the plate and bracket about three more inches than the original design. I will use it for now but am switching as soon as there is an aftermarket bumber and winch set-up that I like.
Old Jun 5, 2001 | 06:40 PM
bobbbb's Avatar
mounted my 2500 on the rear the front mount sucks. My grizzly had the same location. when needed it was under the mud
Old Jun 6, 2001 | 12:36 AM
c77dig's Avatar
Bobbb How did you mount the winch in the rear that is where I would like to put mine because the front mount is too low. I have the winch I just need to mount it and on the 650 you need it. There aren't too many places to hook up to on it to be pulled out. I did get it stuck this past weekend but it was real easy to push out another place the light weight helps.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
