Problems with my Scrambler again!
Old Jun 7, 2001 | 10:06 PM
Xplor's Avatar
Just got it back from the dealer for the re-build and it is screwy once again! I went puttering around at low throttle and it would start to stall and not take the throttle I gave it. I start it back up and it revvs fine as long as I leave the throttle high enough. Stalled 3 times like this.
What is the problem? Rich pilot jet??
Once again, thanks!
Old Jun 7, 2001 | 11:27 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Remove the carb and main jet and blow out with pressurized air. I cleaned out a friend's carb and it ixed his prob. Use carb cleaner and pressurized air.
Old Jun 8, 2001 | 08:03 AM
Balzak's Avatar
After I bored mine and put the larger carb on I had to move the clip on the needle of the carb to the top, that quit the sputtering for me. It would bog out as soon as you gave it gas on the low end but the midrange and the topend was fine. Hope this helps.
Balzak
2000 modded scrambler (just about got the bugs worked out)
Old Jun 8, 2001 | 02:38 PM
KevinDevitt's Avatar
Hi Brian:
I would take it back to the dealer. I know you must be getting a little frustrated with the old Scrambler. Did your sister have her baby? Any ideas on when a silver lake trip might be in your future?
KD
Old Jun 8, 2001 | 03:47 PM
Xplor's Avatar
Hey Kevin. Yep, she had a baby girl. Funny thing is I was out riding with Zorro and he had a wreck at the same time my sis calls me on the cell phone telling me she is going into labor. Two trips to the emergency room that evening.
I just took a click off the needle jet, it was all the way to the bottom and added some air by 1/2 turn. Dealer!
Old Jun 9, 2001 | 11:45 AM
CaptNemo's Avatar
Just a "little rich" eh ????
At least the mechaninc at the dealer put coolant back in the engine...
The wrench ape at the dealer forgot to put coolant back in mine when I had the stock piston replaced under warranty...
Old Jun 9, 2001 | 12:33 PM
Xplor's Avatar
Brought it back to the dealer today and they will take care of it. They are very responsible... Anyone else have problems with the midrange jetting with the 39mm carb???
Old Jun 9, 2001 | 08:36 PM
CaptNemo's Avatar
I sure have had problems with the mid range jetting on the 39 PWK... I've got the burned piston to prove it... I since changed the needle and am still dialing it in.
Old Jun 9, 2001 | 08:51 PM
Xplor's Avatar
Dealer told me he was going to evenly file off around part of the needle. He has done this when tuning race sleds in the past. I hope it works because I hate worrying about the jetting all the time. They stuck in a fatter pilot jet and had the needle on the bottom clip. How is your dialed in??
Worst past is that she was running great after the rebuild and mods this spring...obviously because she was lean! [img]i/expressions/face-icon-small-disgusted.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
