help raptor fan has never worked>>>
Old Jun 10, 2001 | 05:14 PM
dsEATER's Avatar
since I have had my raptor I have never heard the fan run. Today out of curiosity I got out my yamaha manual and check out how to test it. After hooking + to the blue wire and - to the black the fan ran. So the next step is to check the circuit breaker which is supposed to read 0 ohm. mine reads .5 ohm and when I switch my meter to lo ohm then it reads a flashing .1 and then .0 ohm any thoughts? or just go by regular ohm?
Anyone else have fan problems? ever hear your run?
Old Jun 10, 2001 | 07:13 PM
Whit11's Avatar
Had mine since December and its only come on one time. Racing a harescramble and got hung-up in a creek. Had to get off and pull the bike over some bolders and it came on. It shut off soon after I got going.
Old Jun 10, 2001 | 08:49 PM
Sandgod's Avatar
Me and my brother ride together and his has come on a dozen times or so. Mine has not come on yet. He is 50 lbs heavier and usually rides longer at the dunes. I think it takes alot of abuse to get that baby to come on.
Old Jun 10, 2001 | 09:26 PM
SykoQuadRider's Avatar
SandGod, are you trying to say that you flipped your front wheels and you get +5 inches more of width????
Old Jun 11, 2001 | 11:39 PM
DcRAPTOR's Avatar
Mine did the same thing,i let it sit and run in the garage until the warning light came on and the fan never came on, so i did the same test you did and the fan came on so i started chasing wires and under the gas tank there was a wire that was not pluged in it is in a harnass that was on the right side front area under the tank. hope this helps.
Old Jun 12, 2001 | 08:19 AM
dsEATER's Avatar
I oredered a new circuit breaker and thermoswitch, the circuit breaker was plugged in but is reading over o ohm, and figured I want to know it's all working so just ordered the thermoswitch for the heck of it. I wonder if we can get something different to make the fan come on earlier.
speaking of fans on earlier, I remember good old hypertech! they make some cool stuff. I had a 99 camaro SS LS1, with a 6 speed B&M ripper shifter, skip shift eliminator, 4.10 richmond gears, whisper airbox lid, K&N filter, granatelli air flow sensor, hypertech power programmer, hypertech 160 stat, flowmaster 80 serier muffler, mac off road y pipe (without cats) o2 simms, ya I guess you could say I miss my car!!! by the way it would run hi 12's in the 1/4. (just couldn't afford it with my bike and quad haha)
Old Jun 12, 2001 | 01:32 PM
ERICsRAPTOR's Avatar
Mine come on every so often..like this past weekend when I got stuck in a mud pit and it took a little while to get out [img]i/expressions/face-icon-small-smile.gif[/img] It doesn't stay on too long.
Old Jun 12, 2001 | 08:29 PM
Sandgod's Avatar
Yes you do get +5 on width. I put some thick washers on and took the valve stem caps off and it clears by a whisker. Go to Raptorzone and look at the readers rides pics. I catch air like that all day and haven't had a problem! I weigh 190 w/ all gear on.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
