belt
Old Dec 26, 1999 | 07:28 PM
whisky's Avatar
Do you have to have any special tools to put a belt on. because today i snapped one and i got to go get one tommorro. and how hard is one to put on its a 500 scambler its goinin on.
Old Dec 26, 1999 | 08:09 PM
Kagey's Avatar
Nothing to it ,just a socket,ratchet and extension to get the cover off and wrenches to loosen whatever may be in the way(Floorboards,Ect). The pully can be moved with your hand to loosen the belt enough to get it on. Takes about 20 to 30 minutes max ,most of that is getting the cover off and back on.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
Old Dec 27, 1999 | 12:38 PM
whisky's Avatar
how much does a belt cost
Old Dec 27, 1999 | 02:05 PM
Kagey's Avatar
Depending on the dealer or brand between $33.00 and $45.00.
Old Dec 27, 1999 | 07:31 PM
whisky's Avatar
My belt was not snapped it was competly ripped in like 100 pieces.Is there a company that makes a sronger belt
Old Dec 27, 1999 | 07:45 PM
losi's Avatar
Get the belt for the ranger it is very tough. It is quite a bit tougher than the Dayco. HPD sells it as a HP belt retail is 37.50.
Old Dec 27, 1999 | 10:47 PM
Jack's Avatar
I would suggest that you find out why you shredded the first belt, because the same will happen to the next new one. It's not the belt at all. All the belts are ok, regardless of make, it's usually a clutch alignment or other problem that will cause this.
Old Dec 27, 1999 | 10:56 PM
whisky's Avatar
how would i fix that
Old Dec 28, 1999 | 10:57 AM
myscrambler's Avatar
Yep, you should take it to the dealer to get them to align it. It is very easy to put a new belt on but you need a special tool to get it aligned. I just busted my 4th belt in a year which was a Dayco belt on my 99 scrambler 500, I was looking at the dealer's shop manual and just happened to see about how you are suppose to align the belt, and needless to say I just thought you had to put the new belt on. I learned alot this weekend about working on the Polaris, I had to replace six badly worn spider buttons in the primary and three worn buttons in the secondary plus I had to remove the whole pvt system to take my swingarm off to replace the bushings in the swingarm. Now that's work, I had to use 2 special tools to get the clutch apart. I had to use the clutch puller and to get to the spider buttons I had to use the spider removel tool. That was fun, I should have it back together Thursday when the parts come in. I am glad I wanted to put an agressive clutch kit in it or I would not have noticed all of the worn clutch parts.
If you don't get it aligned then you will keep breaking belts, even the tough ones!
L8R,
Steve
Old Dec 28, 1999 | 11:00 AM
Charlie's Avatar
When you find whats wrong with your clutches before you put it back together clean out the air ducts for the cooling. Those 100 little pieces can plug them and you will find out in a hurry how hot that drive system runs.
Charlie
