RANCHER COMPUTER QUESTION
Old Jun 20, 2001 | 03:11 PM
Rancher4x4ESLuvr's Avatar
Does anybody know if your odometer and hour meter reset to zero when you disconnect the battery from the computer,, because I took my battery off to install my winch and i was wondering if it will clear my data.
Thanks
Old Jun 20, 2001 | 03:18 PM
recon1man's Avatar
I think that it will clear all of your data. I know someone with a rancher. He had to disconnect his to get to something on the fourwheeler. It erased his mileage
Old Jun 20, 2001 | 03:26 PM
ms15's Avatar
Isnt that a good thing? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 20, 2001 | 04:02 PM
TEXMud's Avatar
No it will not reset these. I disconnect mine all the time. It will reset your time though.
Old Jun 20, 2001 | 10:44 PM
cartman308's Avatar
I figure it has a backup battery of some kind. a lithium battery probably. mileage and hourmeter will not reset.
Old Jun 21, 2001 | 01:06 AM
trxray's Avatar
Honda is using the same type of system as alot of newer cars and trucks with electronic odometer. you can remove the battery but the odometer still has its memory.
As the vehicle or Quad runs, the miles are being burned or etched into
a chip which dosen't loose its memory. Unless you short it out :-)
Old Jun 21, 2001 | 04:27 PM
cool. thanks for the replies.
Old Jun 22, 2001 | 09:04 AM
beast450's Avatar
Just remember a couple things, never charge battery on quad with it still hooked up and never boost them. Use the pull cord to start if batt is down. If you follow these instructions you never have problems. If you don't it will cause the lithium battery to fail and there goes your speedo memory.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigred20653
Oct 2, 2015 10:05 AM
rgjackson
Sep 17, 2015 11:21 AM
cornermike
Sep 10, 2015 08:30 AM
Elkaholic
Sep 6, 2015 02:44 PM
