Raptor tires
Old Jun 20, 2001 | 07:01 PM
jad's Avatar
jad
I recently blew a front tire and would like some feedback on what aftermarket tire people are using and the results. I am thinking about Bandits or Maxxis. I heard the Bandits are harder and last longer is this true? The front Bandits are more square looking and the maxxis are rounded so the Bandits look like they would sit lower. I am not sure about the tread pattern on the rear Bandit.
Old Jun 20, 2001 | 08:15 PM
leel2's Avatar
Hello,
The Bandits are not as tall as their advertised height, the 22 inch tall rears are only 20 - 20.5 inches. I also know someone who sent their Bandits back because they wanted the extra ground clearance and got Maxxis Razr's. He said that the Bandits were MUCH heavier. I got all new Razr's, and I love the rears, but I just mounted the fronts yesterday. The razr's handle and slide much better than the stock tires, and the 22 inch height keeps me from hitting rocks every few minutes like I used to.
good luck,
Lorrin
Old Jun 20, 2001 | 08:55 PM
arlan's Avatar
I'm having bandits mounted on my Raptor as I type this. 23 inch tall fronts and 22 inch tall rears. I will post on the true height later tonight or in the morning after I pick it up. The reason I went with the bandits was for the puncture resistence and also for a little added height.
Jad, how did you blow the stock tire?
Also picking up the 2002 Grizzly on Friday, it's in.
Old Jun 21, 2001 | 11:52 AM
FISHER1648's Avatar
I have Bandit XCs on both my Warrior and Raptor and they really work well. Side-by-side the Bandit 22" fronts are slightly taller than the stock Dunlop 21". I gained 1/4 inch ground clearance (measured before/after) after installing the 22" bandits. The "braking bars" on the Bandits make a HUGE positive difference in the handleing and cornering and the XCs have very tough sidewalls. I ride in the desert not MX and these are very well suited for nasty, rocky, rough stuff. I get flats with anything else (out here in the dez).....add some monkey snot (for thorns) and you'll be set !
Old Jun 21, 2001 | 04:22 PM
arlan's Avatar
I just measure the Bandit XC's on my Raptor and the 23" fronts measure 21 1/2" and the 22" rears measure 20 3/4" That's alright by me though as the Kevlar belt is what I was after and the tread looks like it will work well for my style riding.
Old Jun 22, 2001 | 11:39 AM
jad's Avatar
jad
Arlan, I blew out the front tire when I hit a capped pipe sticking out of the ground(one where you would shut off someones water from outside of the house)
Old Jun 22, 2001 | 11:44 AM
jad's Avatar
jad
Leel, I asked for the weights on the tires and the Badit XC fronts are about two pounds heavier and the rears are almost five pounds. I want the lighter ones but I'am afraid the Maxxis will wear too quick. Anyone know how fast they wear?
Old Jun 22, 2001 | 01:44 PM
TitanRacing25's Avatar
i would go with bandit XCR's! the nice long last and great handling of a bandit, plus this one is rounded.
Old Jun 22, 2001 | 02:14 PM
jad's Avatar
jad
Titanracing25, what do you mean by this one is rounded? Also I noticed you have a Outterwears air box cover Iam about to install one how much did you change your jetting vs. with the lid on? Thanks.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
