Stuck swingarm bolt
Old Jun 29, 2001 | 06:54 PM
Airtime's Avatar
Is there a trick to getting seized swing arm bolts out? I bent the swingarm on my 250r and it wouldn't be that tough to replace if i could just get the bolt out. Maybe there's some trick that everyone else already knows but i haven't figured it out. I doubt the bold has ever been out.
Paul D.
'86 trx250r
Old Jun 29, 2001 | 07:24 PM
Sandgod's Avatar
Heat the housing w/ a propane torch or settling torch. Don't start melting anything! Put penetrating oil in there first and let it soak overnight.
Old Jun 29, 2001 | 11:42 PM
PamFalcioni's Avatar
use the oil and torch. Get a steel bar that's almost the same size as the bolt, so it hits directly on the end and doesn't mushroom it.
Give it some good smacks with a sledge. If it doesn't budge, you're probably going to have to take it to a machine shop. They'll get it out one way or another.
We've actually had to cut the swingarm out to remove a few pivot bolts, but that's worst-case scenario!
Old Jul 1, 2001 | 07:57 PM
H300F's Avatar
you probably bent the bolts along with the swingarm and that is your problem. just keep pounding them i woould say.
i had the same trouble with my banshee a-arms, i bent the sleeve and the bolt and it was hell to get out the bolt.
Joe454
Nov 20, 2020 01:19 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
