'97 300 rear brake troubles. Help!!
Old Jul 2, 2001 | 03:35 PM
Frank300's Avatar
My rear brakes are now dragging a little and in need of servicing. The problem is, how do I get into the rear brake drum? Keep in mind, this drum is the one that is located near the center of the rear axle vs. the newer models were the drum is located inside the rear wheel area. I know there are 2 large jam nuts on the axle. I can get the outer (1st) nut off but the 2nd nut that appears to be holding the cover to the rear drums will not turn counter clock wise no more than about 1/4 turn. When it locks, it locks solid and will not budge any further. Can someone give me some first hand experience on what to do? I need to be riding by the 4th. Thanks
Old Jul 3, 2001 | 10:26 PM
Frank300's Avatar
Guess I should have saved the technical questions for another page. Seems all that is talked about here are sport quad mods and more simpler issues like tires.
Old Jul 3, 2001 | 10:33 PM
AdamPhillips's Avatar
no u cant ask questions like that in here no one will answer u. ive figured that out a looooooong time ago. it really pisses me off.
Old Jul 3, 2001 | 11:23 PM
Hwilson's Avatar
Here we go. Turn the inside nut toward the rear end. Then turn the outer nut toward the rear end. Then remove the snap ring on the axel that was under the outside nut. Then the O ring on the axel under the coller. Then pull off the coller. Then the tin cover and there you are.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
house1
Aug 9, 2015 10:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
