CV boot replacement problem(scram 500)...please help
Old Jul 13, 2001 | 07:54 PM
ferd350CT's Avatar
I'm a little confused on how to get new CV boot on.I have the machine on a lift with the front drive axle out of the front strut.I cut off the damaged boot.Now what?Do I remove drive axle from center gearcase and forcefully slip on that way?How do I remove it?Do I take apart CV joint?how?I have a service manual but it very confusing reguarding this precedure.While I'm asking a drift punch would be?Thank you all for helping.Duh,almost forgot 2000 scrambler 500 4X4.CV protectors ordered already.
Old Jul 13, 2001 | 08:25 PM
RickRitter's Avatar
The drive shaft will pull out of the wheel hub . It has a circlip on it that will compress under some pressure of tugging on it . It is kinda tapered inside as to let the circlip compress . Give it a few sharp tugs on it and it should come right out , however sometimes they put up a fight .
Old Jul 13, 2001 | 08:36 PM
ferd350CT's Avatar
Well, going to tug.......THANKS
Old Jul 13, 2001 | 10:04 PM
ferd350CT's Avatar
Three tugs and presto! Thanks Rick!!Should I remove all the old grease with parts cleaner?It does not look contaminated but I did ride a few times with a large gash?
Old Jul 13, 2001 | 10:13 PM
soggyrider's Avatar
Yes, absolutly, if you think there is any dirt in the grease, clean it out. Otherwise the dirt will wear away at your joint and you will be buying a new cv joint.
Old Jul 14, 2001 | 02:07 AM
RickRitter's Avatar
Over cleaning won't hurt a thing . If it was mine , and the grease looked real nice , I wouldn't be digging around a lot , but if you see crud in there clean it and regrease . Have a nice weekend .
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
Rooky
10
Jun 23, 2015 09:35 PM
DOC HOLIDAY
Jun 15, 2015 05:00 PM
DOAinNY
Jun 11, 2015 10:34 PM
AdrenalinFreak
Feb 15, 2001 12:40 PM
