Sportsman 500 Shifter
Old Jan 20, 2000 | 08:27 PM
mac1181369's Avatar
The shifter on my 2000 sportsman won't shift into high or reverse. If you pull it all the way back, it goes into neutral, and forward (whether you try to go into high or low) it goes into low. What should i do to fix this?
Old Jan 20, 2000 | 08:37 PM
rooster's Avatar
Shifting linkage needs to be adjusted.
Old Jan 20, 2000 | 09:06 PM
mac1181369's Avatar
Any input on how to do that? And what this is to be done to?
Old Jan 20, 2000 | 09:42 PM
rooster's Avatar
The rods that connect the shifter box (up front, what the shift lever goes to) to the transmission in the back, need to be adjusted. There is a jam nut that you loosen and then you turn the rod itself to make it longer or shorter, just like a tie rod. When done (when it shifts decently), tighten the jam nut, and you're good to go!
Old Jan 20, 2000 | 10:24 PM
SWAC's Avatar
To add to Roosters post, after you adjust the connecting rods, check the movement of the shifting lever with the engine off, to make sure you can pull it out to the side to allow shifting into low. I had to readjust mine this morning and high and reverse were fine, but I couldn't get it into low. So a little fooling around with the rods, and I was back in business.
Old Jan 20, 2000 | 11:45 PM
Pfelect's Avatar
Also watch out for left hand threads!
Ronnie Crecelius Xpedition 425
Old Jan 21, 2000 | 12:40 AM
SWAC's Avatar
No kidding, I almost rounded off one of the shaft threads without looking first!
Njrider1230
Jul 29, 2023 05:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
frostphase
Aug 19, 2015 07:11 PM
Schneider
Jul 24, 2015 05:05 PM
