Piston for a DS650
Old Jul 16, 2001 | 11:01 PM
Air's Avatar
Air
Has any one put in a Alba Piston. If so did you change the cam. Did it help much?
Old Jul 17, 2001 | 11:49 PM
300exSTER's Avatar
I own neihter, but i'll guarentee that a piston/cam and a valve job will improve everything, bottom/mid/and top end. Big imporvment i'd bet. Porting and carb and hell you'd be able to call it "modified" [img]i/expressions/face-icon-small-smile.gif[/img]
ryan
00 ds
Timmy Boy uppers aarms, Razrs Rears, Douglas .190 rims, Renthal bars, Custom Endcap, Team Pami CDI, PEP steering stabalizer, K&N air filter, Graydon Nerf Bars, Asv clutch perch, 909 grips, Timmy Boy fender support/mounts (rear)
district 23 motocross/harescrambles.
Old Jul 17, 2001 | 11:50 PM
300exSTER's Avatar
Oh yeah, just the cam and piston and i'm assuming you'd probably actully loose some of your low end, the valve job would clean up the lower range. Somethin like that
ryan
Old Jul 18, 2001 | 03:31 AM
Knutz's Avatar
Not with our cams[Team Pami]! You don't lose a thing if you chose good cams for the motor that you have. That is why we offer 3 different cam choices.
Old Jul 18, 2001 | 10:37 AM
Air's Avatar
Air
Knutz, What Piston and cams would you reccomend for a 75% Duner 25% mountain Rider (elevations to 11,000 Ft)
Old Jul 18, 2001 | 01:09 PM
Knutz's Avatar
To make the right selection for you, I would have to look at a few other factors.
1. When you do your 75% time at the dunes, is it alot of drag racing, or jumping and general riding as well?
2. Are you willing to run 95 octane or better fuel for a little more power, or would you prefer pump gas?
3. The mountain riding you do, is it fire roads or tight trails? [What sorts of speeds do you ride at?]
Besides the 3 choices of cams that I might recomend for a quad, we also have a few different compression ratios for our pistons. These questions will help us figure out what combination will be best for your riding and your motor.
Old Jul 18, 2001 | 11:41 PM
Air's Avatar
Air
I do alot of mixed riding everywhere. I had a 440ex with 11:1 compression and ran well on pump gas at this altitude. I would probably want to stay aroud this ratio. The cam is another decision I would like an all around cam.
Old Jul 18, 2001 | 11:58 PM
Knutz's Avatar
I would recomend our 11.2:1 compression piston then[pump gas friendly]as well as our "sport" cams. This combination will give the best combination of ridability and performance for your style of riding.
Old Jul 19, 2001 | 12:33 AM
Air's Avatar
Air
Price? Also HP est. Using stock carb for now thinking about a bored FCR.
Old Jul 19, 2001 | 01:02 AM
Knutz's Avatar
E-mail[knutzconcepts@msn.com] or call[(702)236-6852] between 8:00A.M. and 7:00P.M. Monday-Friday and we can discuss your exact needs and cost.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
