98-99 bigbear is hard to shift into 1st gear,Why?
Old Jul 20, 2001 | 01:36 PM
kpwhite's Avatar
I have found that the 98-99 350 bigbear 4x4, i just bought, is hard to shift into first gear.
Any suggestions guy's?
Thank's.
Old Jul 20, 2001 | 01:56 PM
TL4x40's Avatar
Check the shifter linkage and if it is tight, adjust the clutch play.
TL
Old Jul 20, 2001 | 02:02 PM
kpwhite's Avatar
To adjust linkage are you talking about the screwhead down by the linkage that says"increase-decrease"?.
If that's not what it's for, what is it?
Old Jul 20, 2001 | 02:40 PM
TL4x40's Avatar
That's it. I had to hold the stud with a screwdriver then loosen the locknut with a box end wrench. Do NOT do this with the motor running. I went a little to far to start with and it shifted ok but was slipping. Do a little trial and error til you are happy with the shifting as well as the throttle response. There is a guy online Vince's Cycle in Va that makes an updated shifter linkage for the Wolverine that will also work on our Bears. If that does fix it , give him a call. Really nice guy who sometimes has quads he is parting out as well. I picked up a starter from him last fall.
Tim
Old Jul 20, 2001 | 02:47 PM
kpwhite's Avatar
Thank's, I'll let you know how it goe's.
Old Jul 21, 2001 | 10:29 PM
kpwhite's Avatar
The day we replaced the big boot i cracked off the linkage twice,(the piece that is about 4 inces long and has "elbows" on each end).
That is why i posted the question about stiff shifting.
I did as you sugested. I turned the screw (clockwise)in three increments (testing each,which improved shifting into first each time) to half a turn of the screw.
It definetly worked!
I drove the bigbear for 4 hours today and never craked the elbow piece.
I think tommorow i'll turn it a 1/8 more.
It still is a little stiff but no noticeable slipage.
Thank's again!
Old Jul 22, 2001 | 11:06 PM
TL4x40's Avatar
Glad it worked. That linkage piece is the one that Vince make a better mouse trap. His web site has some good photos of the parts. vincescycle.com
Glad I could be of some limited help,
Tim
Firefighter400
Oct 8, 2022 06:38 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
