What is the deffinition of 25x11x10?
It's basically the overall width-the widest point on the tire. Some companies measure width from tread only, while others measure from sidewall to sidewall (sidewalls stick out further, thus giving a "wider" measurement). Bead to bead width will vary from a few inches, to however wide a rim you mount them on. So, like Andy said, your tire measurements for that size are 25" tall x 11" wide, and need to be mounted on any 10" diameter rim.
Don't worry about having to buy new rims if you don't want too. You can easily fit a full 12" wide tire on the stock rims with no problems. The only question is will the 12" wide tire fit your machine without rubbing anywhere-that I can't answer for ya on the SP's, one of the others will have to do that.
Best of Luck, hope you really enjoy your new tires when you get them!
Mike
Mike
hey, would i be able to fit 23x8x10 front tires, on 10" rims? There are already 23x10x10" tires on the front rims of my trail boss,and i just wanted narrower tires. I dont wanna have to change the rims though, but i will if i have to. THANKS
