TCS rear shock work. What are your opinions?
Old Jul 28, 2001 | 05:18 AM
wcy2k400ex's Avatar
Hey everyone. I figure that in the next 12 months or less, I might be able to, and it might be time, to send my rear shock off and have reworked. I would like to have the shock rebuilt, converted to dual-rate, and revalved to match my TCS fronts.
A few days ago, I called CT Racing and talked to someone about the shock work from TCS. It was something like $550 to get the work I wanted done. We didn't get into any extreme specifics, but I believe that the price was for everything I wanted done. I was wanting the dual-rate conversion, rebuilding, and revalving of my rear shock. Does this price sound right to you all? Also, what do you TCS rear shock owners feel about it? Do you like the dual-rate setup? Is all this work well worth the money? Or should I send my shock off, and have somewhere else revalve and rebuild it?
Any insight is GREATLY appreciated. I need help making a decision on this work. I want the money to be spent on something worthy. Thanks.
Old Jul 28, 2001 | 09:19 PM
YamahaRider's Avatar
It`s $450 to have all that stuff done. I don`t have it but any shocks are better than stock.
Old Jul 30, 2001 | 02:30 AM
quadMXer70's Avatar
Yeah, man... I think YamahaRider is correct. It's like, $450 for the rear shock revalve and conversion to dual-rate. If CT is charging $550, don't buy from them... Check out K&K ATV Supply. They're price is $450. I have TCS suspension on my 250R, and the fronts are sweet, but TCS isn't able to convert the stock 250R rear shock to dual-rate. I've felt some 400EX rear shocks that were converted to dual-rate and they feel soooo much better. The conversion will be worth your $450. I'm considering saving up $850 and buying a TCS dual-rate rear shock for my 250R since they can't convert my stocker. Like I said, dual-rate is the way to go.
Old Jul 30, 2001 | 05:46 AM
wcy2k400ex's Avatar
Thanks a lot for all your help guys. CT is charging $450 for the rear work, but I wrote down the price of the front work ($550) on accident. I'm wanting to get my fronts revalved and converted to triple-rate, and have my rear done as well. I believe that my a conversion on the rear will help make the fronts perform better. My fronts are awesome, but valved a little soft now.
My biggest problem right now is money, or the lack of. Since Publisher's Clearing House hasn't knocked on my door during the Super Bowl, and I haven't won the Powerball, I guess my wish list is going to have to checked off in steps.
Old Jul 31, 2001 | 11:56 AM
bubba1005's Avatar
Carver Performance is also a very good company. The turn around time is pretty quick too. I just had mine done it only took them 2 days once they got it.
Old Aug 9, 2001 | 05:36 PM
killefitt's Avatar
Does anyone convert the 250R rear shock to this dual rate with longer travel?
And how does the longer travel work, is the extra 1.5" set up as sag then the swingarm can go down lower from stock?
Rod
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polarisman1123
Aug 13, 2015 08:13 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
