Prairie 650 Hard to start when Hot
Old Jul 30, 2001 | 10:23 AM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
How is everyone’s Kawasaki 650's starting when they’re hot? Mine doesn't start worth a crap when it’s hot. Once started it's fine but it sure takes allot of cranking when hot.
Is anyone else having this problem?
Has anyone figured out the trick to starting the big beast hot?
Old Jul 30, 2001 | 11:03 AM
Squire's Avatar
No, I haven't had any problem starting my 650 when its hot. However, often, I have had to use the choke when starting the atv when its cold and when the the temperature is quite high, especially first thing in the morning. I would suggest that your problem is one for the dealer to investigate.
Old Jul 30, 2001 | 06:21 PM
ron11199's Avatar
Mine you have to give a little gas when starting.dosent matter weather its hot or cold.
Ron
98 lakota
02 v-twin 650
Old Jul 30, 2001 | 07:29 PM
Zsilverado's Avatar
My 650 starts right up when hot I have rode on some very HOT! days for long periods of time and it all ways started right up.
Old Jul 31, 2001 | 02:08 AM
c77dig's Avatar
I would say mine is harder starting when it is hot than when it is cold cold it starts right up but hot you have to give some gas and a few cranks
Old Jul 31, 2001 | 09:56 AM
slot's Avatar
Mine also starts fine hot or cold. Have you had your 650 serviced yet?
650 & 660 pics
Old Jul 31, 2001 | 10:54 AM
bigwave's Avatar
Has anyone noticed that when you remove the gas cap you can here a fairly loud sucking sound? I wonder if my fuel tank vent is partially clogged. About a month ago we were playing submarine and I sunk the entire rear-end way past the fuel vent system and this was in really sandy water or at least it was sandy by the time I was through.
And NO I had zero problems with water getting anywhere it shouldn't (unless it plugged the fuel vent), as soon as I got the rear end to move a little the big hog pulled itself right out.
Old Jul 31, 2001 | 03:59 PM
MJSTX's Avatar
Mine starts good in warm weather (30.C). I got mine a week ago and have alreay 10 hrs. on it, runs very well so far! Had some glycol coolant leaks , this was due to loose hose clamps at the thermastat housing. Will change all fluids this weekend. Great quad so far!!
MJSTX
MikeyBoyesq
Nov 27, 2020 02:44 PM
kwackermann
Jun 24, 2015 10:18 AM
1000gade
May 27, 2015 12:37 PM
bodatiouskid
May 27, 2015 08:33 AM
dunc_n
Aug 26, 1999 09:32 PM
