Rear brake cable sticking
Old Jul 28, 1999 | 08:03 PM
Debbelson's Avatar
The rear brake cable on my Kodiak is sticking and starting to cease up, is there anyway to clean it or is it inevitable that I need to replace it. Deb
Old Jul 29, 1999 | 11:24 AM
Harold's Avatar
Are you sure it's the cable, it could be that the brake cam is getting rusty in the housing!!!
Old Jul 29, 1999 | 05:04 PM
hot_shoe_cv's Avatar
Deb, A breath of fresh air to see a post from a female of the opposite sex(the redundancy is intentional) .
I am not all familiar withe Kodiac. However, if it has drum brakes as opposed to discs, it is bossible that you have accumulated mud, debris, or rust from the above inside the hub. This could prevent the cable from doing it's job of activating the brake shoes. If your rear brake is indeed a drum type, I would dis-assemble the hub and determine if it is free and clear of the
above obstructions. If not removal of same should clear up your problem. While you're in there,use some WD40 to free up any moving parts including the springs, takingg care not to get any on the shoes themselves.
If you do a lot of riding in mud or water you would be wise to do this maintainance quite often; it's the price you pay.
Come back again, this forum NEEDS YOU.
Cal, the Az hard packer
join the Blue Ribbon Coalition online at www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 07-29-1999).]
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
toonces
Aug 13, 2015 01:48 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
