On-Command System
Old Jul 29, 1999 | 07:17 PM
FALCON's Avatar
I'm looking at buying a Kodiak 4x4 and was hoping that I could get some responses about the On-Command 4x4 system that the Kodiak and Grizz use. I know nothing about it other than it's push-button. I'm really interested in how it actually works, both on the trail and the technical aspects. Is it similar to the Polaris system? Thanks.
Old Jul 30, 1999 | 03:53 AM
A_TEAM's Avatar
Well, it doesn`t work like the polaris. First, as soon as you push the button, it engage the four wheel drive system. It doesn`t have any sensor. Once it`s engaged, the front end is a limited slip differential so it work the same way as the other 4x4.
Sylvain Belec 400 scrambler - 225 moto4
Old Aug 4, 1999 | 08:07 PM
cisko61832's Avatar
On a Polaris, you push the 4wd button, but you don't have 4 wheels driving until the rears slip a little. On the griz/new kodiak, you press the button and the 4wd is turn on right then, you don't wait for slippage-then it operates in full-time 4wd with a standard limited slip front diff until you press the button againto turn it off.
Later, Shawn
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
