Grizz 660 reverse limiter now bypassed
Old Aug 10, 2001 | 10:08 PM
alaraptor's Avatar
Look on the side where the gear shift is take off the side cover and you will see just to the right of the petcock a clump of wires in a white bracket with a rubber strap around them,find the green one with a white tracer on it and unplug it.Take the female side and ground it to the frame via a bolt and you will know it is the right wire because when you unplug it with the key switch on the reverse light will stay on wether in reverse or not.When it is grounded the reverse light goes out.
I will be outting a toggle switch on mine so that I will have an override switch on so in case someone jumps on it and nails it in reverse and flips it.It is a handful in reverse with no limiter.
I will try to find the limiter on the Differential lock later on.It"s really easy just like on the kodiak but easier I believe.
I got the Idea from the kodiak post so thanks whoever.
[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 10, 2001 | 11:10 PM
PADZZ's Avatar
Thank you for your time. Let us know when/how you put that switch on.
Old Aug 11, 2001 | 12:07 AM
imported_juggalo's Avatar
thats cool but why would you wanna take the limiter off?
Joe454
Nov 20, 2020 01:19 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
