size of blackwaters to fit big bear
Old Aug 31, 1999 | 07:21 PM
bigbear350's Avatar
i got a 98 bigbear 350 4x4 and i was wondering what size of blackwaters could i put on my bear without a bigwheel kit.
Old Sep 1, 1999 | 02:09 PM
TailFeathers's Avatar
I have 26in. Goodyear terra grips on my big bear with no lift and they fit just fine. And there is plenty of fender clearance. If you actually measured the height of most tires, you would be surprised that they are not as tall as they are advertised to be. TF
Old Sep 1, 1999 | 02:12 PM
As a side note: You'll limit yourself if you plan on using your stock wheels. TF
Old Sep 7, 1999 | 06:11 PM
rrinc's Avatar
26x12x12 ITP Blackwaters on a '96 BB SE.
Good luck!
William Hayes '96 Yamaha Big Bear SE Juneau, Alaska
Old Sep 8, 1999 | 12:54 PM
rgv's Avatar
rgv
I just put a set of Blackwaters on a 91 BB
I went with 26x9x12 on the stock front 6.5" wheels and 26x12x12 on the rear 8.0" wheels, fit perfect, just had a little hammer work to get the beads to seat on the rears.
I have ridden a few machines with the 26x12x12's on the fronts, and the steering was way too heavy for trails and the turning radius was too big. Depending on the riding you do, you may want the 12" fronts though.
By the way, the 26" Blackwaters only measure 24.75" outside diameter mounted on the wheels and 5 psi. They are shorter than the stock Dunlops, something i wasn't too happy to discover.
Raul
2quiker
Mar 22, 2022 08:36 PM
antiguogrumete
Sep 5, 2015 03:41 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
quickwhips
Sep 2, 2015 06:53 AM
snowolson
Aug 31, 2015 03:51 PM
